The Benefits of Having a Water Detector in Your Basement
If you are refitting your basement, then you may need to add several types of alarms, including a water detector, in order to keep your family safe. Basements have lots of pipes, including drain tiles and sump pumps. Detecting a build up of water in your basement is vital. A water detector can alert you to problems you didn't even know you had.
Remodeling the basement can cause a lot of disturbance of old pipes and ducts, which leave them functioning not as well as they used to. They could even leak into the surrounding concrete of floors and walls, causing water stains and problems with hygiene. A water detector will detect the build-up of water below the surface, giving you a chance to fix the problem before anything serious occurs.
Basements are often built below the ground, usually around the foundations. That means that they are sometimes lower than your local water table, increasing the risk of flooding during heavy rains. A water detector can alert you to floods in the basement.
