2 Things to Know Before Attempting to Build Underbed Drawers
When you are living in a small space, having underbed drawers can be the perfect way to get more storage areas in a room. If you have a basic bed frame, and are thinking of adding underbed drawers to it, then there are a few things that you should consider before you begin. Planning these underbed drawers will help to save you from serious problems later on.
1. Keep It Simple
When you are building your underbed drawers, keep it simple. For example, if you have a straight four-legged bed, with no additional frames across the floor, then you may be able to make underbed drawers by converting some other furniture drawers, adding some roller-blade wheels, or similar, and then putting a handle on the outside edge. This will avoid you having to install stops, and is the most basic way of having underbed drawers for storage.
2. Consider the Size
Another important consideration is the size of the underbed drawers. You might want drawers that reach from one end of the bed to the other, or you may prefer two smaller drawers at the far end of the bed. Building smaller underbed drawers is likely to be simpler, if you have never done this kind of thing before.
