2 Tips For Adjustable Pantry Shelving 2 Tips For Adjustable Pantry Shelving
When you want to improve the quality of your pantry shelving, then you should consider purchasing some which are adjustable. These types of shelves are movable, meaning that you can adjust the positions depending upon the type of food you are storing, or to accommodate a large item. When you are thinking about installing adjustable pantry shelving, there are a number of things that you should consider.
1. Pantry Shelving Materials
Begin by deciding what type of adjustable pantry shelving you would like. You might want to choose metal ones, as these are more adaptable to being regularly moved, but if you have a wooden floor or wall area in your pantry, then you might want to use wood as an alternative. You could consider plastic shelving, which is lightweight and non-corrosive, but these are only suitable for light materials.
2. Hanging Shelving
As an alternative to traditional pantry shelving, you might consider hanging shelving. These are fitted into the pantry by the use of hooks, making them much more adjustable than the shelving which has to be fitted to the walls. These shelves are typically made from metal, and can be bought in a range of sizes, so they can be used even in small pantries.
