3 Advantages of Installing a Basement Wall System 3 Advantages of Installing a Basement Wall System
If you are looking for a permanent solution for your damp basement, then you may benefit from installing a drainage basement wall system, which will drain the basement for you. This method of preventing damage in your lowest area may be expensive, but it has a lot of advantages.
Installing a basement wall system will prevent moisture from building up along the walls and ceiling of your basement. Such moisture encourages the growth of fungi, including dry rot and damp mold, which are both harmful to the structure of the building. Some fungi are actually dangerous to humans. You would be better off looking after your health by removing any potential problems from your system.
Along with rot, moisture can attract insects such as termites, ants, and other pests to your basement if you don't have an effective way of removing the water. Insects can seriously damage the foundations of a building. They are well worth eliminating.
Aside from attracting mold and insects, water is a pest all by itself. It can erode concrete and other materials, andvprovides cavities in which insects and other animals can make their home.
