3 BBQ Propane Tank Care Tips
If you use a gas grill, then you’ll use a bbq propane tank with the grill. It’s much simpler and less messy than having to deal with charcoal and fluid, and the grill heats up much more quickly. However, you have to look after a bbq propane tank. It contains gas, and that makes it potentially dangerous. Handled wrongly, it could explode. It’s important to know the right way to care for a bbq propane tank in all types of weather.
Set Up
Connecting the bbq propane tank correctly is vital. Make sure the valve is fully closed before you place it next to the grill. When you connect the hose from the grill to the bbq propane tank, you should only hand tighten it. Don’t use pliers or you can easily overtighten it. Only then should you open up the valve on the propane tank. Only open it one full turn; you don’t need more than that. Turn off the valve once you’ve finished grilling so no gas can escape.
Weather
You can keep your propane tank hooked up to the bbq all year if you wish, although it’s probably best to disconnect it at the end of bbq season. One thing you do need to do is check the bbq propane tank regularly. As it’s made of metal, it can be affected by the weather. Rain can cause the metal and the connections to rust, for example, while a cold spell can make the metal contract and cause cracks. By inspecting the tank regularly, you’ll be aware of any abnormalities. If you spot any, don’t attempt to use the bbq propane tank again. Disconnect it and use a new tank the next time.
Care
A bbq cover is a good way to care for a bbq propane tank, as it will cover the entire grill, including the tank. A cover is cheap and will keep the rain and snow away, as well as protect the bbq propane tank from the heat, which can be very dangerous.
You need to keep the tank out of direct sunlight, and under no circumstances should you have it out in heat above 110 degrees Fahrenheit. On very hot days, disconnect tank and put it in a shady place. If you leave the bbq propane tank out during the winter, put an insulation sleeve over it. That will prevent the tank becoming too cold as well as keeping out possible rust and corrosion.
If you go a few weeks without using the grill, check the connections on the bbq propane tank before using it. Corrosion can build up over a very short period of time, and connections can become loose. Always check the connection before you open the valve on the bbq propane tank to be certain it’s tight. Treat a bbq propane tank with care, always remember that its contents can be explosive, and inspect it regularly and you should have no problem.
