3 Best Radiator Hose Clamps to Buy
  • 2-5 hours
  • 25-50
You obviously want radiator hose clamps that you are not going to have to worry about. There are several different types out there. You will simply need to make sure that you get the right kind for your vehicle. The better the fit, the better they will be at their job. Make sure that you are aware of the pros and cons of each type of hose clamps that you look at before you decide on any that you wish to purchase for your vehicle.
1 - Band Clamp
This is the most commonly used type of hose clamp. This type of clamp will use a screw that will either loosen or tighten your slotted clamp. So when it comes to removal, you will find that these types of clamps are the easiest. Because they are the most commonly used, they are the easiest to find and work on. These clamps are typically very reliable and can provide you with years of service as long as they are properly taken care of and you do not excessively cause stress to your radiator.
2 - Crimp Style Clamp
Most of the automobile manufacturer’s use this type of clamp. Should you have to remove them you will have to take out the entire radiator hose. These types of clamps are obviously reliable as they are used in most new cars. However, you will find anything that a manufacturer uses in a car is not always the best. You will be able to rely on these types of clamps, but there is always room for improvement. They are not the most expensive, but also not the least. The same can be said for their reliability. They are not the most unreliable but you will be able to find better out there. However, if you are looking for clamps that will get the job done then these are the ones for you.
3 - Wire Crimp Clamps
A lot of import cars use this type of clamp. When it comes to removing them it uses a combination of the screws with the band clamp and having to remove the entire hose like the crimp style clamp. These types of clamps are a pain to get removed. Because they are used on imports typically they are much harder to find. You will see that they do not always work well on cars that are not imports. They are very specific to the type of vehicle that they should be used on. Because they are harder to find and are used on imports they are also generally more expensive. While they work well whenever they are on the right vehicle, you will need to make sure that you have the right type of car for these to work.
Overview
Basically what it all comes down to is the type of vehicle that you have and the type of driving that you do. You want to get a heavy-duty type of clamp if you do a lot of hard driving. However, if you are not particularly hard on your car then an average type of clamp could work for you.
