3 Considerations When Plumbing Your Swimming Pool
Swimming pool plumbing is really best left to the professionals unless your swimming pool is suitable for self installation. Before considering plumbing your own pool in to your back yard, make sure you consider other installation issues prior to beginning.
1 – Choosing your Pool
It is vital you choose the right pool for your own circumstances and requirements. Vinyl, concrete, fiberglass and above ground pools are the most common types. Decide if you need to have your pool above ground or below. You can also opt for an "endless" pool, which has an artificial wave system, allowing you to swim for miles without moving an inch.
2 – Costs
Consider the cost and set a budget level for your pool. Self-installation above ground pools can be a far better cost effective way to install a pool, and it also means that if you move, you can take it with you if you wish. Above ground pools can be as little as $130 and as high as $20,000.
3 – Drainage
It is vital to consider the drainage of your pool and how the pipe and plumbing system will fit into your current situation. You will need to consider skimmers, main drains and the excavation of the ground.
