3 Dangers When Considering a Loft Bed Ladder
Installing a loft bed ladder is a very common practice when you have a loft bed. However, there are some dangers that you may want to consider with these devices. Here are a few of the dangers associated with loft bed ladders and what to watch out for.
1. Falling Off the Ladder
The biggest and most prevalent danger associated with this is that you or a child could fall off of the ladder. This could present you with any number of dangers including broken bones. When using a loft bed ladder, you need to be very careful not to lose your balance, or you could end up being injured in a fall.
2. Slipping on a Rung
Another danger that you need to be aware of is slipping on a rung of the ladder. Your foot could slip and fall in between two ladder rungs. This could also cause broken bones or other serious complications.
3. Ladder Falling Over
In addition to falling off of the ladder, the ladder could also fall on you. Some of these ladders are very heavy-duty and could seriously injure someone if they fell on them.
