3 Flagstone Patio Designs 3 Flagstone Patio Designs
A flagstone patio is a type of sandstone that is most commonly used for paving roofs. There are several different types of designs that you can choose from that will allow you to personalize your landscape. There is no limit to the types of designs that you will be able to come up with. You will find that it all comes down to what works for you and what will look best for your patio. You are basically going to be looking for something that will complement the rest of your home and the outside décor that you have surrounding it. Make sure that you put some thought into the type of design that you choose so that you are completely happy with your decision.
Uniform
If you do not wish to have any specific design, then you can always go the uniform route. This is a design that you will use with the help of square sandstones. You can lay them similar to tile, with each square next to the other. You can also go with a brick pattern. This is something that is still uniform but adds a little extra touch of something different to it. If you are worried about having to crazy of a design, then this is something that you can think about doing that will allow you to get the most out of your flagstone patio design.
Circles
There are circles, squares and rectangles as well as odd shapes. You can mix and you can match or you can simply go with just one shape. If you go with the circles, then it can be difficult for you to be able to have the ability to get them to match perfectly alongside each other. You will have to more than likely to a lot of cutting got make sure that they are side by side while still maintaining their circular shape. You will have one circle and have other circles cut around it to make sure that they all fit together. While circles are difficult to cut around, they can also be a lot of fun to have. They add a different look and flavor that you would otherwise not be able to have with a square or a rectangle look.
Odd Shapes
The odd shapes are basically sandstones that are not shapes at all. They can be made to add a design that is completely unique to you. You will find that it will take some extra planning so that you will be able to make sure that you can get them to fit together and form a shape that can be pieced in. It will be a lot like doing a puzzle. You will simply need to plan it out and figure out what you can do with the shapes that you have and make the most out of them. This is by far the most creative that you can get with these types of sandstones. However, you will find that they will take much more work to prepare when compared to the circles and especially when compared to the uniform look of squares or rectangles.
A flagstone patio is a type of sandstone paver. There are several different types of designs that you can choose from that will allow you to personalize your landscape. There is no limit to the types of designs that you will be able to come up with. You will find that it all comes down to what works for you and what will look best for your patio. You are basically going to be looking for something that will complement the rest of your home and the outside décor that you have surrounding it. Make sure that you put some thought into the type of design that you choose so that you are completely happy with your decision.
1 - Uniform
If you do not wish to have any specific design, then you can always go the uniform route. This is a design that you will use with the help of square sandstones. You can lay them similar to tile, with each square next to the other. You can also go with a brick pattern. This is something that is still uniform, but adds a little extra touch of something different to it. If you are worried about having to crazy of a design, then this is something that you can think about doing that will allow you to get the most out of your flagstone patio design.
2 - Circles
There are circles, squares and rectangles as well as odd shapes. You can mix and you can match or you can simply go with just 1 shape. If you go with the circles, then it can be difficult for you to be able to have the ability to get them to match perfectly alongside each other. You will have to more than likely to a lot of cutting got make sure that they are side by side while still maintaining their circular shape. You will have one circle and have other circles cut around it to make sure that they all fit together. While circles are difficult to cut around, they can also be a lot of fun to have. They add a different look and flavor that you would otherwise not be able to have with a square or a rectangle look.
3 - Odd Shapes
