3 Most Common Sustainable Resources Used in Carport Designs 3 Most Common Sustainable Resources Used in Carport Designs
Carport designs can come in many shapes and sizes. If you are concerned about the environment, you may want to think about some of the sustainable materials that you can use to create a new carport. Consider the following sustainable resources that you can use when planning with a carport design.
1. Wood
One of the most common things that you can use to make a carport with is wood. While it may take some time to regrow a tree after it is used, it can definitely be regrown. For certain parts of construction, you may also use reclaimed wood, which has been harvested from older buildings, like barns and homes.
2. Bamboo
Another sustainable resource that you could use is bamboo, which is one of the most sustainable resources in the world today. As soon as you cut down a bamboo stalk, it will immediately start regrowing, and only takes about 3 to 5 years to grow back to maturity. This means that you can cut down bamboo without depleting the world's supply.
3. Rope
Rope is another material that can be used in the construction of a carport. This can be used to hold the heavy materials together and it is completely sustainable.
