3 Reasons a Sanding Sponge Might Come in Handy for You
If you are fond of time-saving tools, then you may be considering investing in a painter's tool known as a sanding sponge. If you are a home improvement fan, you may find yourself repeatedly completing paint jobs, which can become boring and tedious over a long period of time.
One way of saving yourself time and labor from these backbreaking tasks is to get a hardworking piece of equipment such as the sanding sponge to help you manage your project. There are a number of reasons why you should consider using a sanding sponge when you are doing any paint job around the home.
1. Ease of Use
Unlike more complicated power tools, or a sanding tool, the sanding sponge is very simple to use. If you're completing a long project, working out how to effectively use something more complicated can be annoying. Rather than having to use loads of cables and connections, or having to sand using a small piece of steel wool, you can use the sanding sponge straight out of the packet.
2. Flexibility
Unlike your power tools or basic hand tools, the sanding sponge can adapt to a range of different situations. Since it has a foam block as the center of the sponge, you can use the tool wet or dry. This can help you get rid of dirty marks, or to wipe away spackle and other drywall plaster smudges, depending on what you need the sponge to do.
Since you can wet the sponge, you can also wash it off after use, meaning that one of these tools can be reused many times. The foam in the center also allows you to rub down molded wood, such as you might find on stairs or around the edges of doors. The sponge can be pushed into the molding so that the sandpaper outside touches as much of the wood as possible. This features also means that you can scrub paint off tiles and other uneven surfaces.
3. Efficiency
The sanding sponge is one of the best ways of quickly getting rid of plaster, paint and even dirt from the surface of a wall. You are not limited to just using the sponge after painting, either, as you can use it when you have applied a filler to cracks in the surface of the wall, when you have drilled holes or screws into the wall, and simply for wiping away stains once the paint has dried.
The tool is much better at all of this than choosing to use a paint scraper to try and remove paint and plaster. Since the sponge can be damped, you can wipe off wet paint stains quickly and efficiently.
