3 Signs of a Clogged Fuel Filter
a Fuel Filter
If your vehicle has recently had engine problems that range from start-up issues to stalling, you may have a clogged fuel filter. Below are some of the characteristic signs of a clogged fuel filter.
1.) You Have Trouble Starting Your Engine
There are a number of possible causes for engine start-up issues, and a clogged fuel filter is chief among them. So, if it often takes several tries to start your vehicle's engine, a clogged filter may very well be the culprit. Alternatively, if your car's engine simply refuses to start altogether, a clogged filter is one of the likely causes.
2.) Your Car's Engine Runs Erratically
Another common symptom of a clogged fuel filter is an engine that frequently sputters or stumbles while your car is being driven. Thus, if you notice that your engine tends to stall or sputter, especially during acceleration, a clogged filter may be the cause.
3.) Your Vehicle's Engine Sporadically Loses Power
If you've noticed that your engine has a tendency to lose power while your vehicle is being driven, this may be the result of a clogged filter. In some cases, your engine may lose all its power, causing the vehicle to stop entirely. Should this occur in the middle of an area prone to heavy traffic, the results can be fatal, so take care to have your car looked at immediately if you suspect this to be the case.
