3 Things to Check When Kitchen Shelves Start to Bend
Whether they are used alone or within the confines of a cupboard, kitchen shelves can be used to solve a range of storage needs. However, if they are put under too much pressure, they can begin to bend.
1. Weight
Consider the weight of the items that are being placed on the shelf to determine whether it is too much for the kitchen shelves to handle. Remove all the items and check whether the bend is still evident. Determine whether the manufacturer makes any recommendation on weight limit.
2. Supports
Kitchen shelves may begin to bend if the supports that hold them in place are insufficient or defective. Replace any fasteners that have suffered damage. If the structure of the surface the shelves are fixed to is damaged, locate the shelves elsewhere if repair is not possible.
3. Damage
It will be necessary to check whether the integrity of the shelf remains intact. If possible, remove the kitchen shelves from place so that they can be examined properly. If the material is such that it cannot be manipulated back into its original position, it will need to be replaced to ensure that the problem is not allowed to worsen.
