3 Things to Know Before Replacing a Toilet Hex Nut
Many common toilet issues require the replacement of a hex nut. The hex nut of the toilet connects the toilet itself to the floor and prohibits the toilet from moving or shifting while in use. When replacing the hex nut of a toilet, there are a few tips and recommendations to keep in mind.
Tip 1 – Don’t Over Tighten
The first thing to remember when replacing the hex nut of a toilet is tighten the hex nut only enough to secure its hold. Over tightening a hex nut can cause damage to the toilet because an over tightened nut can crack the toilet. As well, over tightening the hex nut can strip the nut and loosen the grip of the toilet.
Tip 2 – Use Washers
When using and replacing hex nuts, you should utilize metal washers. The washers can protect the base of the toilet from damaged by the hex nut.
Tip 3 – Use Ease with Covers
When the hex nut of the toilet is covered by a cap, use ease when removing and replacing the cap. This will ensure the cap does not crack or break and can be replaced over the new hex nut to conceal it.
