3 Tips for Choosing a Portable Garment Steamer
A portable garment steamer is a handy tool to have when you need to get rid of wrinkles and dents that have may have formed on your clothes. There are different kinds of portable garment steamers to choose from. You can tailor you choice of portable garment steamer around you specific needs, your lifestyle, as well as your budget.
1. Understand the Three Types of Portable Garment Steamers
The first kind of portable garment steamer is the floor model. This original garment steamer stemmed from dress and tailor shops that needed this tool to remove wrinkles from the clothes they were going to display at their shop windows. The second kind of portable garment steamer is the compact handheld steamer. This is useful for when you go traveling because it is very portable and you can bring it with you. This is a handy tool to have especially when you need to remove wrinkles from the clothes that you stuffed in your luggage when you travel from one place to another. The third kind of portable garment steamer is the garment steamer tools that come with a purchased steam cleaner.
2. Know the Advantages of a Garment Steamer over the Traditional Flat Iron
The use of a garment steamer to freshen and smooth out clothes is gaining ground on the traditional iron. You do not need an ironing board to use a garment steamer; however, you will need to make several passes of the portable garment steamer over the garment you are working on to eliminate wrinkles. A portable garment steamer not only rids your clothes of wrinkles, but also freshens and dusts away your garments, keeping them well-maintained and always new-looking.
A portable garment steamer can be used on almost everything that can take moisture and on most garments such as jackets and suits. It can also be used to smooth out bed sheets, pillow sheets, curtains and draperies.
3. Benefits of Using a Portable Garment Steamer
A portable garment steamer is lightweight and travels well in a small suitcase. It can eliminate wrinkles on most types of clothes, and smooth out fabrics and materials of bedroom items such as sheets, pillowcases, and curtain. It is, therefore, a multi-purpose tool. If you use a portable garment steamer, you do not have to dry clean your garments anymore since it makes use of steam from a tap water reservoir attached to the unit. A portable garment steamer is economical and effective, so it will save you both time and money. The difficult thing about using a flat iron is that you need an ironing board in order to use it. The unit, along with the ironing board, is bulky and cannot be transported easily from one place to another. If you are someone who is always on the go and needs clothes to look presentable after you travel, a portable garment steamer is a good investment.
