3 Tips for Cutting Carpet Straight 3 Tips for Cutting Carpet Straight
Carpet cutting is something that is going to be necessary when you install new carpet. When you cut carpet, you need to make sure that you cut it straight. Here are a few tips for cutting carpet straight.
1. Use a Straight Edge
One of the most important things that you will want to do is use a straight edge. A straight edge is going to be necessary to guide your knife along the edge of the carpet. If you can find a long, metal straight edge, this is going to be the best thing to use.
2. Go Slowly
One of the biggest problems that people have with cutting carpet straight is that they try to rush. When you rush through the process, you are most likely going to end up making a mistake. If you will go slowly and deliberately, there is much better chance that you will be able to cut the carpet straight.
3. Focus on a Row
In many types of carpet, you will be able to see the rows of the carpet. When you are doing this, you should be able to focus on an individual row in the carpet. This will help guide you and make a clean cut.
