3 Tips for Spacing Pipe Hangers 3 Tips for Spacing Pipe Hangers
There are several important factors that must be taken into consideration when deciding the proper spacing for your water pipe hangers. If these factors are not taken into consideration appropriately you may compromise the integrity of your wall or ceiling as well as causing pipes to burst under their own weight. There are readily available charts that will take into account these factors and give you the proper spacing.
Tip 1 - Wall Thickness
It is important to accurately be aware of the actual thickness of the wall you are hanging the pipe from. This will directly influence the amount of weight that each hanger can hold without compromising the integrity of your wall.
Tip 2 - Weight of Filled Pipe
You will also need to take into account the weight in foot pounds of your pipes when filled with water. This will give you an accurate idea of the distance necessary to hang your pipe hangers at as well. If you use the empty weight of your pipes to make your judgments this will give you an inaccurate reading versus the weight when water is actually flowing through your pipes.
Tip 3 -Pipe Size
Spacing charts will also take into account the size of your pipes and the size of your pipe hangers when judging the optimal distance at which you should hang them.
