3 Tips for Staining Softwood Flooring 3 Tips for Staining Softwood Flooring
If you plan on staining your softwood flooring, you will want to keep a few things in mind. Here are a few tips to help you through the process with ease.
Tip 1 - Sand Well
The first thing that you need to do is sand down the softwood flooring. You have to be careful as you go along and progressively get finer with the grit. This step is one that you do not want to rush through. Sanding properly will ensure that your floors look amazing once they are stained.
Tip 2 - Apply Clear Conditioner
Using a clear conditioner on the sanded wood helps to keep the stain from soaking in too far. You can use a rag to apply a thin layer of conditioner and allow it to sit for about 30 minutes before you stain.
Tip 3 - Start Small
You want to begin with a small amount of stain because softwood flooring tends to allow the stain to spread and seep in easier. Try a little at first and then use more until you get the look that you desire.
