3 Tips for Working with Solid Rivets
A solid rivet is a fastening device that is used to secure or connect two separate materials. Solid rivets are used for strong and sturdy applications and connections. When working with solid rivets, there are a few tips that can help make your project and rivet installation a success.
Tip 1 – Use Proper Length
When working with rivets Remember to calculate the proper length to get the rivet size correct. The length of your rivet should always be 1 to 1½ times the size of the rivet diameter.
Tip 2 – No Air Hammers
When purchasing a rivet gun, do not be fooled into believing that an air hammer is an adequate substitute. Air hammers hit very hard and very fast. This is not the desired effect of a rivet gun. It is true that an air hammer can install a rivet, but it can also damage the surrounding materials and ruin your project.
Tip 3 – Don’t Overdue the Air Pressure
When setting air pressure for your rivet gun, do not assume that more is better. This is definitely not the case. The higher you set the air pressure, the harder the rivet gun will be to control. By setting your air pressure higher than what is needed, you can actually cause your precision to diminish and could even damage the surrounding materials.
