3 Types of Weed Cutters Explained
Weed cutters are a must-have for garden maintenance. These tools help you trim weeds easily and efficiently. Appearance, functionality and features differ from one model to the next. However, a basic categorization can be done according to power source. To help you understand what’s out there, below is a useful guide.
1.   Electric-powered Weed Cutters
You plug these into a power outlet for it to run. Most models come with extremely long cord length. This allows you to extend your reach into wider areas. Electric cutters are easy to use. They don’t produce as much noise as the gas and battery-powered types. This enables you to work with minimal noise disturbance to the neighborhood. Most electric cutters can work up to 1 hour. Beyond this, the motor is over taxed. They’re not as durable as the other two types. This is partly because the motor is susceptible to wear and tear when it overheats. This necessitates frequent repair or replacement of parts. You also have to be careful not to use it in wet environments. It puts you at higher risk of electric shock. The long cord length, although useful, may also be a hindrance. It may make mobility slow and difficult as you work. It may also prove difficult to reach the furthest areas where you desire to work. This limits the functionality of electric cutters. Electric cutters are available for under $100.
2.   Gas-powered Weed Cutters
Gas cutters are the heaviest of the threeversions. They also have the highest power capacity. This allows you to trim thick weeds and brush quickly. They’re the most efficient if you have a large area to clear of weeds. They’re also the most efficient for farmland tasks. You can run the motor for up to an hour and a half. However, gas cutters are noisier than the electric and battery-operated models. They also cause more pollution to the environment since they produce a higher level of exhaust fumes. Due to their heavy weight, transport can be a problem. Gas cutters are the most expensive. They range between $100 and $300. You must also spend additionally on gas and oil. The operational costs add to overall costs.
3.   Cordless Weed Cutters
These are powered by batteries. They provide the least power. Cordless cutters are only good for light weed growth in small areas. You cannot use them to trim thick weeds or brush. However, they’re convenient if you have to work in an area without electricity. The absence of attachments such as a cord makes it easier to maneuver a cordless cutter. You’re not limited in where you wish to work. The various models may run for 20 minutes to 1 hour. You have to re-charge the battery after you complete your work. Due to their limited power availability, cordless cutters may limit the amount of work you can do. It is best to always have an extra set of batteries for backup. Battery-powered trimmers are the cheapest available. You can easily get one in the range of $40 to $80.
