3 Types of Wood Stair Treads
If you are getting a new home with stairs, or you wish to perform repairs on an existing staircase, you may find yourself in need of new stair treads. Whatever your reason for wanting to install new stair treads, you should choose your materials carefully. The difference in the finished results of a well-planned staircase and a poorly planned one can be very big. Read this article to learn about the different types of wood to use for stair treads.
Solid Wood
Solid wood can make excellent stair treads for many reasons. Solid wood is durable and long lasting. It can be re-finished many times; however, solid wood can be expensive because of the required thickness of the stock that is turned into stair treads. The cost of solid wood stair treads is increased further by the amount of skill required to construct and place them properly. Additionally, solid wood is prone to expanding and contracting more than engineered wood. For this reason, it can be more vulnerable to cracking or warping, particularly if it is exposed to humidity or extreme temperatures.
Engineered Wood
Engineered wood has its own set of advantages and disadvantages. It is less vulnerable to moisture, heat, and cold. It is also less durable, and may wear out more easily than solid wood.
False End Treads
False end treads for stairs are a less expensive option. A false end tread is a small add on that hangs over the edge of the stair, rather than a full piece of material covering from front to back. For that reason, they can only be used with carpet.
