4 Advantages of Rigid Roof Insulation 4 Advantages of Rigid Roof Insulation
Rigid roof insulation is a general term that defines a type of insulation. Rigid roof insulation is defined by its panelized construction and predefined shape. Rigid roof insulation is made from several materials including polystyrene, rock and glass. This insulation is precut, but can be trimmed. Rigid roof insulation can also be installed in walls and floors. There are several key advantages to using rigid roof insulation and the following article will cover those advantages.
1 - More Insulation for the Money
When you install other types of insulation such as fiberglass or blown insulation the amount you use can be extensive. This is especially the case when it is used in a roof. Rigid rood insulation due to its construction and shape provides more insulation per square inch of the structure than other insulation. This fact alone warrants the use of rigid roof insulation in your home or building as you pay for what you need. With other roof insulation materials you generally spend much more money hoping you have enough insulation to make it effective.
2 - Durability
The process used to make rigid roof insulation compacts the materials to such a degree that makes it incredibly strong and nearly impervious to rotting. Even rigid roof insulation made out of wood will rarely rot and polystyrene never will rot or warp. Most materials that are used in rigid roof insulation are waterproof and will detract animals from gnawing through it. Rigid roof insulation made out of all-natural materials is even more durable than other insulation due to the process it takes to make it rigid. The only exception is insulation made from gypsum or other rock materials as they can break under pressure. They are better suited for walls and interior installations.
3 - Ease of Installation
One thing that many people want out of insulation is that it is easy to install. This applies to rigid roof insulation to foam insulation. Batting insulation is often blown into the ceiling cavity and is generally trial and error determining how much to use to insulate the roof. There is also foam insulation which has to be measured and cut and then tucked in place. This usually will require that a vapor barrier also be installed on top of it to ensure there are no spaces to allow moisture or air through. Rigid roof insulation is already sized and precut and the installation is done by placing the panels. You would then nail them in place; attaching them to the joists. They are easily trimmed in case you need to cover corners or harder to reach areas.
4 - Effectiveness
Using rigid roof insulation may not be the cheapest solution to your needs, but it will be the most effective. The ease of installation combines with the durability of it as well as the coverage area all make rigid insulation very effective against every circumstance you may come across. The panels create a strong seal along the open areas of the roof which prevent cold and hot air from intruding.
