4 Best Uses for a Panel Saw
A panel saw is a broad generalization which describes any saw that can cut wood into sheets or specifically sized parts. A panel saw can be found in various sizes from small table models to large floor models meant for very large projects. A panel saw can also be found in two different orientations: horizontal and vertical. The following article will share with you some of the better uses of a panel saw.
1. Sign Making
Companies that create wood or melamine signs of various sizes will often have a panel saw in their workshop. With a panel saw a sign maker can easily cut sheets of plywood of various thicknesses into multiple sizes for use as sign blanks. The panel saw creates a soft edge so finishing is at a minimum. With proper planning the panel saw will not create any waste making it a very cost effective tool.
2. Prop Houses
A prop house is a company that provides props for film, television and stage plays. Many prop houses will create their own props and a panel saw is an invaluable tool they employ in their set department. Many scenes found in entertainment are filmed in front of a backdrop that is made from wood and then expertly painted. The panel saw is capable of cutting very large pieces of plywood that can be used for this industry. Prop houses can also create dummy walls which are walls that are on wheels and can be locked in place and then moved as needed. A panel saw is often used to cut a large sheet of plywood to the correct dimensions of the needed wall and then painted. This saves the prop house added cost in framing and using drywall to create actual walls.
3. Custom Cabinetry
There is nothing worse than having a cabinet that does not properly fit in a space or close. These issues are usually caused due to improper cutting of the materials. A panel saw is able to be set with specific dimensions and then cut the wood appropriately. The cut will be identical each time it is made. This means the cabinets will be able to be put together without any problems because every piece will be the same size every time. Custom cabinets are often exclusively prepared using a panel saw due to the expense associate with custom jobs.
4. Dressers and Tables
Continuity of pieces is important when designing and building a dresser or a table. If the pieces cut are too short you may have to start over. Cutting wood for a dresser is especially made easier using a panel saw. A dresser consists on a back, two sides, a top, bottom and drawers. If you inspect your dresser you will notice that all pieces that went into making the dresser are identical pieces of wood. They are the same type of wood and the same thickness. Cheaper dressers use sheets of wood for the back. A panel saw was most likely used to cut out those pieces due to their uniform nature.
