4 Innovative Materials to Use as Decorative Panels
Decorative panels for walls are quickly becoming a popular choice for room makeovers. They can cover up old walls to make a room look new again, add dimension and style or do the job quicker and more cheaply than more traditional materials and construction. Wood panels give a room a classic appeal, but it's not the only option for materials. Here are 4 innovative materials to use as decorative panels:
1. Stoller Metal
Considering a metal finish for your wall panels? Give Stoller metal wall panels a try. These are hand-etched directly on sheets of classic metals and work well if you want to give your panels an organic look. They come in a variety of colors, ranging from gray to browns. What's unique about the Stoller metals is that they add movement to the room, giving it a great visual effect.
2. Bead Board Panels
If you enjoy textured materials, then you'll like bead board panels. These have grooved surfaces made up of wood material. There are real (and non) wood materials to choose from. Bead board panels are popular for their visual aspects. They make a room look much more interesting than bland-looking walls. You can also buy ones that are pre-finished, if you select bead board panels made of real wood.
3. Tiled Wall Panels
Gone are the days when you had to pay for expensive tiles for your bathroom. Tiling floors can also be labor intensive, and some people have had to hire professionals to complete the job. Tiled wall panels solve this problem by giving the appearance of tile in the bathroom, without the hefty expense. You glue the tiled wall panels over existing walls. It can look as expensive as putting down real tile, without spending even one-third as much. Standard wall panels are not recommended for use in the bathroom, because they're not made to withstand high levels of humidity and moisture.
4. Fabric Wall Panels
One solution to solving interior design issues is using fabric wall panels. You can buy ones wrapped in fabric to match any room you're working on. Making your own is even better. Select the fabrics you want, even ones with sentimental value, add padding and wrap them over standard panels. Another benefit to using these is the fact that the fabric can absorb noise quite well. You can use these to control the noise level between rooms.
As decorative panels increase in popularity, there will be more and more innovative materials on the market available to you for all sorts of projects. For example, look for more panels made of organic materials in the near future. The key to selecting panels is to budget for the project, keeping in mind the purpose for the panels in the first place. If style is your primary concern, then you have a wide array of options to choose from and your challenge is to keep costs down.
