4 Removable Kitchen Backsplash Ideas
If you are looking for removable backsplash ideas for your kitchen, you have come to the right place! For many people, the functional benefits of a backsplash do not always justify the permanent installation of a fancy backsplash. For others, the ability to switch between different backsplashes is an attractive option. Regardless of your reasoning, there are a number of options available for anyone seeking to install a removable backsplash.
1. Removable Tile Backsplash
For a basic, functional backsplash, one thing to consider is making your own removable tile backsplash. To do this, you will first need to purchase a 3/8-inch piece of plywood or particle board from your local hardware store, cut to the size that you will want your backsplash to be when it is completed. Next, purchase enough tiles to completely cover the board you have selected. Consider purchasing tiles with a glaze finish over them as opposed to a textured or unglazed tile for this purpose.
Backsplashes are installed specifically because they are usually placed in areas where grease or food has the potential to splatter, and unglazed or textured tiles will be both prone to staining and difficult to clean if they are used. Once you have all of your tiles, begin to glue them onto the board using liquid nails or a strong epoxy. When you have finished, you can either hang or lean your new backsplash on the wall it is designed to protect.
2. Get Creative with Colors and Patterns
Borrowing from the idea above, remember that you do not have to use tiles of the same color to complete a project like this. Consider purchasing a number of tiles in different colors and use your imagination to create patterns and color schemes that will fit your kitchen area. You can even purchase several backer boards and make more than one removable backsplash to suit the seasons. You could make a red and green backsplash for Christmastime and an orange and black backsplash for halloween.
3. Create a Tile Mural
This suggestion also applies the same general concept explained above, but takes it one step further yet. When you are purchasing tiles to affix to your backer board, consider purchasing tiles with a mural printed on them. When you arrange the tiles in order on the backer board, you will have an attractive image of your choice to spruce up your kitchen area. Once again, feel free to purchase more than one set of tiles in order to create different scenes to match holidays, or just for a simple change of scenery from time to time.
4. Commercial Options
There are a number of relatively inexpensive removable backsplash ideas that are available from national retailers. There are plastic, vinyl, tile, and even fabric backsplashes available from various retailers if you are willing to put the time in to shop around. These backsplashes have the benefit of being cheap, so you can afford to purchase more than one in different colors, but the downside is that they are often less attractive than their tile counterparts.
