4 Supplies You Need to Tile
If you plan on doing it yourself, you will need several supplies to tile a floor. Here are a few of the most commonly used supplies for a tile installation.
1. Wet Saw
One of the most important tools for you to have is a wet saw. A wet saw is a type of saw that is specifically designed to cut tile. It shoots a stream of water onto the tile while you are putting it so it will not chip or break.
2. Trowel
A trowel is another tool that you are going to need for this job. A trowel will be necessary to spread out the tile adhesive on the floor. You can also use a trowel to apply the grout after you are done installing the tile.
3. Adhesive
In order to install tile, you are going to need some adhesive. You could potentially use thinset or mastic depending on your preference. Mastic comes pre-mixed in buckets and most thinset comes in large bags that you have to mix with water. In most cases, thinset is going to be less expensive.
4. Tile Spacers
Tile spacers are something else that you are going to need in order to lay tile. These are used to ensure the proper spacing between the tiles.
