4 Thermal Drapes Basics Everyone Should Know 4 Thermal Drapes Basics Everyone Should Know
Thermal drapes have a lot of great qualities that can add both style and function to your home. They’re designed to keep your rooms cool in the summer and warm in the winter as well as cut down on utility bills. Whether you’re installing sliding door drapes or bedroom drapes, you can reap the benefits of thermal curtains to enhance any room.
1 – Thermal Drapes are Eco-Friendly
Thermal drapes take pressure off of your heating and cooling system by reducing the amount of energy used to cool or heat your home. All you have to do is close the thermal drapes, and you can cut the energy used down by up to 20% total over the course of the year. By using thermal drapes instead of air conditioning you can reduce your impact on the environment.
2 – Thermal Drapes can be Customized
In many cases, when you’re looking for affordable thermal drapes, they’re rather plain. Use your imagination and customize them by sewing on fringe or beading, adding more fabric to the main curtain panel, or even using an iron-on adhesive to glue on appliqués. This is the biggest advantage to buying basic thermal drapes—you can make it whatever you want it to be.
3 – Many Fabric Choices
While inexpensive thermal drapes can be customized, you can also find high-end thermal drapes that have nice designs and provide great function. While the prices may be high, the quality is usually good. You can find thermal drapes in silks, satins, cottons and blends. Some can be washed in your washing machine, others need to be dry-cleaned. Make sure you read the label before you purchase them.
4 – Thermal drapes Save Money on Utility Bills
When you cut your energy usage by 20% per year, you save 20% on your bill every year too. In 2008 the average utility bill per month was approximately $100. Thermal drapes can shave about $20 a month off your bill if used all around the home. This is a savings of $240 a year!  It’s like having nearly 2 months of utilities for free in your home.
Since the average set of thermal drapes from discount retailers is about $40 per set, you can purchase 4 sets of thermal drapes and they will literally pay for themselves by the time a year has passed from the date you installed them.
As you can see, there are some pretty great things about thermal drapes that should motivate you to buy them, hang them, enjoy them, and reap the benefits.
