4 Things to Check First when Looking at Used Water Well Pumps
Water well pumps are used in the water system to move water. Water well pumps can be expensive to purchase but the need to replace an old pump is a must. You can purchase used water well pumps, but there are several things you need to look for prior to doing so. The article that follows will share some of these important things with you.
1 - Construction
Water well pumps can be found in a myriad of styles and materials. Choosing the right one is very important. Water well pumps that are all plastic are more desired over models that include metal.
2 - Rust
It is important to make sure that if the pump has metal that the metal is in good condition. Remove the rust completely if you can, but do not purchase water well pumps that are very rusty as other damage is most likely possible. This includes inspecting the inside of the pump.
3 - Rot
Water well pumps can often have wires for power purposes as well as rubber hoses. Inspect the hoses for rot as well as holes or gashes. Look inside the pump as well and inspect the wires for corrosion or rot in the cover.
4 - Power
Only purchase water well pumps if they match the power of the current pump.
