4 Things to Consider Before Installing Bifold Doors 4 Things to Consider Before Installing Bifold Doors
If you are thinking about installing bifold doors, there are a few things you should consider and think about. Bifold doors are a classic way of adding a little style to your room and can be fully opened to allow easy access behind the doors. However, they can cause problems with flooring as well. There are both pros and cons to bifold doors and you should consider them all.
#1: Easy Access
If you are installing bifold doors to a closet, you will be able to open them up and have easy access to your whole closet. Sliding doors do not work as well, as you have to open them one way or the other. This will make removing or placing things in your closet much easier.
#2: More Room Around the Doors
Swinging doors will prevent some objects from being close to the doorway, whereas bifold doors allow you to have furniture much closer to the them. This will help you open up smaller areas and utilize your space better.
#3: Great for Separating and Opening Up Spaces
By placing sliding doors between two rooms, you can open up or close up the two spaces easily without having a swinging door in the way.
#4: Flooring
If you have an area rug near the closet, it could be more difficult to open and close the closet doors as it may catch on the fibers. If the closet is not high enough, it can also hurt tile or wood flooring by scratching it.
Bifold doors can be a good addition to your home, and you should consider installing them.
