4 Tile Roof Styles
Tile roofs not only provide an aesthetically pleasing alternative to asphalt, but they can provide your home with long-lasting protection. Tiling is energy efficient in both the cold and heat, and economically sound due to its extended life. There are many styles available, each with its own benefits and characteristics.
Concrete
Concrete tiling is renowned for its overall durability. Since concrete is a Class A material, it is not susceptible to fire, bugs, water or moderate winds. The proof of concrete’s toughness comes in the form of lifetime warranties most manufacturers provide. If the tiles are installed correctly, they can offer protection for over 100 years.
If you’re picturing concrete tiling to be unattractive, rest assured that there are many ways to make it beautiful. Concrete can be stained any color, sculpted or designed to resemble another material.
Clay
Clay and concrete are similar in their ability to resist fire, water, wind and insects. The most common type of clay tile used for roofing is the Spanish style, which is a reddish color and appears on houses built in the traditional Spanish design with stucco walls. A more versatile type is the flat clay tile, which can be manufactured to resemble a slate roof and finished in a variety of colors.
Clay is advantageous because it is typically the lowest priced tiling option, but will still give your roof decades of protection. If you’re planning to install a clay roof, you’ll need to get your home inspected first to make sure the structure is strong enough. Clay tiles are heavy and should not be installed without ensuring there’s support for them.
Metal
Metal tiling is a low-maintenance choice that is great for areas with a lot of snow or rain. Aluminum is considered the longest lasting metal to use in roof tiling, and often comes with a lifetime warranty. Other metals may experience rusting after some time, but they are unaffected by most problems seen in other types of roofing. Copper is known for keeping fungi from growing, as it is poisonous to the fungi and will prohibit it from thriving.
Solar
If you’re looking for a way to slow your energy bill down, investigate solar tiling. Recent advancements in technology and design have made it possible to have a few different styles. In the past, solar tiles were placed over existing tiles in a patch, but there are more and more companies offering a system where the solar tiles are locked together and fitted to the whole area of your roof.
Solar tiles are the most expensive option among roof tiling styles, but they typically last over 25 years, and the amount of money saved over 25 years will more than repay the cost of having them installed. Solar tiles are an investment, and you can expect to see your money recuperated after a few years. With other roof tiles, you will not see a return on your investment with additional savings in energy bills each month like you will with solar.
Conclusion
Before settling on a certain roof tiling system, work with your local roofing businesses to see what they would suggest for your house and the climate you live in.
