4 Tips for Front Bumper Replacement 4 Tips for Front Bumper Replacement
Front bumper replacement can be easy as long as you know where everything goes and you follow these simple tips on getting a new bumper. It's also a very important process as sometimes the bumper is your lifeline when it comes to an unexpected accident. Having a bumper in excellent condition is always important, as safety should always come first. If you suspect that your bumper is not in top condition, here are a few tips to help you detect any damages and undergo front bumper replacement.
Tip 1: Know What a Bumper Does
Before you proceed to the process of front bumper replacement, you have to first know what a bumper is and what it does. The bumper is a part either on the front or the back of the vehicle that actually sustains the damage of an impact. They are usually reinforced so as to strengthen them for the force of a potential collision. Having bumpers that are not damaged can reduce the amount of injury that a passenger of the vehicle may sustain, if ever. They are usually required to be installed on all vehicles.
If a bumper has any damage, you could guess that this is a serious problem that will show itself only at the last minute. Before any serious accident occurs, you have to inspect your bumper for any signs of damage or imperfections.
Tip 2: Detecting Imperfections on Your Bumper
Look thoroughly for damages in your bumper that might bring its structural integrity into question. Cracks and fissures may show up over time. Some may be small that you'll need to run your finger to detect them. Check for these signs to determine if you actually already need front bumper replacement.
Tip 3: Choose a Replacement Bumper
Ever since Federal Motor Vehicle Safety Standard Number 215 was implemented in 1876, vehicle manufacturers have been required to follow standards in bumper production. Although it has been revised through the years due to highly developing standards of safety, the fact still remains that when choosing a front bumper replacement; make sure that it adheres to these regulations.
Tip 4: Replacing the Bumper
For your tools to accomplish this task of front bumper replacement, you'll need a jack, a ratchet and socket set, the bumper and the bumper mounting kit. While supporting the front bumper with the jack, remove all the connecting mounting bolts. Take the bumper out slowly and set it aside. If the bumper is connected to accessories such as lights, now is the time to disconnect their wiring and take them out as well. Compare the original bumper to the replacement one to determine the correct placement. Attach the replacement bumper carefully, along with the additional accessories, and bolt tightly back together.
Once you have successfully installed your new bumper, do not forget to test drive it for a short distance before concluding that the bumper is sticking to the car correctly. That's all that is involved in front bumper replacement. Don't just enjoy your new bumper. Inspect it regularly to make sure that it is still strong and able to withstand damage.
