4 Tips for Installing a Chicken Wire Fence
Chicken wire fencing is a popular way to contain small animals such as chickens and rabbits. The purpose of the chicken wire is not only to protect the animals from predators but to prevent them from escaping. The ideal chicken fence that a builder should strive for is a strong and firm wire that is able to withstand attacks from both the contained animals and the predators of contained animals. The wire should not be harmful to the contained animals. Here are some tips to keep in mind when installing the chicken wire. Be sure to ask the local authorities for permission first.
1. Anti-Predator Feature
One crucial physical aspect of the fence is that it should be able to scare off potential predators. Don’t count on the fence to block them. Some predators are agile enough to leap over the fence. The best way to warn predators to stay off the fence is to install barb wiring on the exterior of the wire fence. You should also install barb wiring on the inside of the wire fence to deter animals from jumping over. When installing the wire on the exterior, make sure that the barbed wire doesn’t poke through the interior of the fence. Once predators get stung a few times by the wires, they will learn to stay away.
2. Chicken Fencing Must Be High and Deep Enough
The wires and the wooden stakes of the chicken fence should be plunged deep enough into the ground. Animals that have good digging ability can dig a hole under the fence and escape it. Rabbits will also attempt to squeeze through the holes or nibble on the wire fence to create a hole big enough for them to escape. When installing the fence, dig a trench that outlines the perimeter of the chicken fence. The trench should be at least 6 to 8 inches deep.
3. Use Nature to Your Advantage
You might be surprised to find out that nature can offer natural strong protective barriers for your cage. Taking advantage of natural barriers can help you save time and money in installing a chicken fence. For example, a tree can act as a natural stake. Use a tree as part of the perimeter. A tree has deep, entrenched roots to make sure rabbits don’t dig under the fence. The bark of the tree is strong enough to withstand an attack from both predators and animals contained within. Find ground that has rocks buried underneath and mark these places as a potential perimeter outline.
4. Planning Is Important
Before you even begin to even start laying the wires, plan the perimeter outline first. You need to scout the perimeter area for any potential natural objects that may harm your animals. Be careful where you position your fence and only install fencing in areas that belong to you. You also need to know what type of animals you are going to keep in the fence. If the animals are rabbits, you definitely want to make the fence a lot taller and deeper. You can afford to be flexible with chicken fencing as they are bendable to form any shape that you desire. So don’t worry about the shape of the perimeter.
