4 Tips for Installing a Split Heat Pump
If you want to install a split heat pump, then before you begin, you will need to have a fine  understanding of the process necessary to install these kinds of heat pumps. A split heat pump has two connections, one into the ground, and another into the home, very much like a split air conditioner. Ducts fitted to the home connection then carry heat into the home, with each duct being able to warm one room only. If you think that this kind of heat pump is the best for you and your household, then you should find a few hints and tips on getting the best from your installation very useful.
The Split Heat Pump
Before installing the split heat pump, it is important to understand a few things about the system. Firstly, installing the split heat pump is a similar process to fitting a split air conditioner, in that there is a part inside, and a part outside, the home. The inside part needs to be connected to each of the rooms that you want to heat or cool, so you should be prepared for a lot of work involving removing walls or ceilings and then refitting them once the work has been done. You will also have to position both the inside and outside parts of the pump in order to get the best supply of heat to the rooms you want.
Make a Plan
The best defense against all of this hard work is to plan carefully before you install the pump. How many duct ends you have will determine where you place them in the home, for example do you want to warm the living room plus one of the bedrooms, or do you want to warm the bedroom plus the kitchen or dining room? Get a blueprint of your home, and lay out the ducts carefully on the drawing, so that you can see exactly what you will be getting by placing your ducts in a certain area. While you have the blueprints out, consider the pipe and electricity work already in your home, as you will not want to have to remove portions of that in order to fit the duct.
Take Some Time
Fitting the split heat pump is not something that can be done overnight, or in a few spare hours on your weekend, so you will need to wait until you have at least 10 days away from work in order to get the job done from beginning to end. Don't forget that you will not only have to install the pump, but also all of the pipework that goes with it.
Get Some Help
When you are planning to install something of this size in your home, you will need some assistance. You might call on friends or family to give you a hand, as this can make the work a lot easier, and they will also be necessary when you are moving the pump before installing it. Get your family to set aside a day or two to come and give you a hand.
