4 Tips for Properly Using a Dead Blow Hammer
A dead blow hammer is a device that is used to soak up the tremors emitted when a hammer strikes. This particular tool is very important since it prevents damaging any soft surfaces. Moreover, it also reduces the rebound and improves the strike force of the hammer. This particular hammer is also very efficient since it reduces the stress on the elbow or wrists while working with the tool. Although the dead blow hammer functions very well as a shock absorber, improper use of this tool can also result to failed projects.
Tip 1 - Use Safety Glasses When Using A Dead Blow Hammer
This particular type of hammer contains a lot of loose sand or other particles which are necessary to break the vibrations made during the hammer strike. Moreover, the striking surface of the hammer can also be made from other materials that break up when struck and may send tiny slivers all over the workplace. This is the reason why this particular type of hammer is not recommended to strike chisels, drive nails or hit other types of sharp objects that can damage its hard covering.
Tip 2 - Don’t Strike The Hammer Using A Lot of Force
Unlike the conventional hammers, the dead blow hammer can be made from different types of materials which include aluminum or polyurethane. These materials are prone to breaking when struck on a hard surface using a lot of force. Even if your dead blow hammer does not break after striking it using strong force, the problem is that continued use of this hammer decreases its life cycle.
Tip 3 - Use The Hammer On Smaller Jobs
Another tip in order for you to properly use the dead blow hammer is to make sure that you only use it on small and short jobs. This particular type of hammer will not last long if used in tasks that require a lot of force. In fact, there are a lot of construction works that require taxing tasks such as hammering through walls, nails and house joists.
Do not use blow hammers in these sensitive environments unless the manufacturer vouches for the durability of the casing of the hammer. On the other hand, if you plan to use the dead blow hammer for more difficult tasks, make sure that it comes with a second coating which protects the  hammer from further damage thus increasing its life span. The perfect settings where dead blow hammers can be used include chassis repairs and also minor repairs which include pavements and flooring.
Tip 4 - Store The Dead Blow Hammer In A Secure Place
Make sure that you keep the dead blow hammer in a secure place in order to prevent the hammer from any unnecessary damage caused by dropping the tool by accident or by stacking different tools on top of it.
