4 Tips for Removing Septic Tank Enzymes
When it comes to septic tank enzymes, there are a few things you will want to keep in mind for removal.
1. Do Not Pour Hazardous Chemicals
One big tip to follow is to lower or eliminate all of the chemicals you use in your septic tank. While you may think you are helping out a clog, back up, or similar situation, you could really be causing more problems with enzymes. The chemicals add to the problem instead of resolving it and create more trouble in the long run.
2. Keep Your Reservoir Filled
This tip is one that many people do not know or think of. By keeping the reservoir filled, you will not have to deal with adding or monitoring enzymes in your septic tank. This will help to regulate the amount of enzymes and allow you to keep from having to remove excess in the future.
3. Use a Bio Safe Cleaner
Using a bio safe cleaner not only helps to remove those enzymes from your septic tank, it also allows you to keep the tank clean and safe in the future. These types of cleaners are great because they get the job done, they are environmentally friendly, and they are strong enough to get rid of build up and scum as well as enzymes and odors. But at the same time, they aren't so strong that they would harm the septic tank in any way. You can typically find these types of cleaners online as they are often hard to locate in a store. Or, your plumber may know of a place that sells or supplies them.
4. Dilute the Mixture
Diluting your enzyme treatment with warm water can benefit you in several ways. You will be able to keep the enzyme count down to begin with, allowing it to flush out faster and easier when they are done. Also, you can prolong the life of your treatments and cut down on the costs. The solution will be strong enough to clear out the grime and build up, but also not be so strong that it is corrosive to your septic tank.
Each one of these tips can help you keep your septic tank running efficiently. If you experience any serious or alarming problems, you will want to contact a professional to make sure that you are not causing any further harm to the system. When searching for an enzyme cleaner or ways to flush out your tank, you want to keep the age of the tank as well as type of tank in mind as they do differ and will matter in making a decision on a final product. Always read instructions before using any product that you have not already used or was not recommended by a professional.
