4 Tips on Attic Rafter Insulation
Rafter insulation is something that necessary within your home. You will find that an attic is something that needs to be insulated just like the rest of your home. It will prevent your attic from getting too cold in the winter. If an attic is not properly insulated, then whenever it is cold, the heat from the house will escape through the attic and it will end up taking a lot more energy and money to get your house properly kept warm during the winter months. Attic rafter insulation is something that is not very difficult to do and will end up saving you a lot of money and trouble in the long run.
Right Size
It is important that whenever you get the fiberglass roll insulation that you keep in mind that it is going to be going in between rafter beams. You will be able to find this type of insulation at most places that you can find regular insulation. It is important that you are able to get the kind that goes for rafters so that you will not have a lot of insulation cuts that you have to make and not too much will be wasted. When in doubt, ask an associate what the best kind would be. In order for you to be able to make the best decision possible for what size insulation to get is to measure your rafters before you go to the store.
R Value
The R value for insulation basically means how much insulation it can ultimately provide. You will need to make sure that the R value is one that you feel comfortable with. Typically, whenever you are getting insulation for your attic rafters, something between R-30 and R-60 is the best way to go. However, if you have a larger attic or home or live in an area that has severe winters, then you may want to consider getting a higher R value. For mild winters and smaller homes, a smaller R value may be necessary.
Laying Insulation
Whenever you are putting down the insulation, you will need to make sure that you measure the length of each of the rafters so that you will know how long the insulation piece will need to be. Get the sheet of insulation rolled out and cut it accordingly with a utility knife. Once the piece of insulation has been laid, make sure that you have it secured into place and staple it with a staple gun. It is a good idea to have your staples laid out about every 6 to 8 inches along each piece that you lay.
Safety Tips
It is important that you dress accordingly whenever you are laying any type of insulation. Gloves and long sleeves and pants will help to protect your skin. Insulation can make skin very irritable. You should also consider goggles and a dust mask for whenever you are cutting the insulation to make sure no fly away pieces get in your face.
Rafter insulation is something that is necessary within your home. You will find that an attic is something that needs to be insulated just like the rest of your home. It will prevent your attic from getting too cold in the winter. If an attic is not properly insulated, then whenever it is cold, the heat from the house will escape through the attic and it will end up taking a lot more energy and money to get your house properly kept warm during the winter months. Attic rafter insulation is something that is not very difficult to do and will end up saving you a lot of money and trouble in the long run.
1. Right Size
It is important that whenever you get the fiberglass roll insulation that you keep in mind that it is going to be going in between rafter beams. You will be able to find this type of insulation at most places that you can find regular insulation. It is important that you are able to get the kind that goes for rafters so that you will not have a lot of insulation cuts that you have to make and not too much will be wasted. When in doubt, ask an associate what the best kind would be. In order for you to be able to make the best decision possible for what size insulation to get, measure your rafters before you go to the store.
2. R Value
3. Laying Insulation
4. Safety Tips
It is important that you dress accordingly whenever you are laying any type of insulation. Gloves and long sleeves and pants will help to protect your skin. Insulation can make skin very irritable. You should also consider goggles and a dust mask for whenever you are cutting the insulation to make sure no fly away pieces get in your face or into your lungs.
