4 Tips to Unclog a Refrigerator Drain 4 Tips to Unclog a Refrigerator Drain
If you've recently found yourself plagued by a clogged refrigerator drain, you may be wondering how to go about fixing the problem. If so, read on to learn the basics of unclogging a stopped-up refrigerator drain.
Find Your Refrigerator's Drain Hole
After taking care to unplug your refrigerator and shutting off any water that is supplied to it, you will need to locate the device's drain hole. This hole can generally be found at the bottom of your refrigerator's interior, but just to err on the safe side, you may want to consult the device's owner's manual or the manufacturer's website.
Make the Necessary Disconnections
Having located your refrigerator's drain hole, you will need to carefully disconnect the plugs the hold the device's drain tube in place. Once the plugs have been removed, you'll be ready to move on.
Locate the Source of the Clog
You will now need to locate and expel the source of your clog. As refrigerator drain tubes tend to be very thin, you will need to incorporate the aid of a stiff wire to successfully fish out the clog's source. After latching onto the clog, gently pull it out of the tube. Having remedied the clog, you may now reconnect your drain tube, although it is recommended that you flush your refrigerator drain with warm water before doing so.
