5 Types of Playground Flooring
5-10 hours
Beginner
- 50-500
Choosing the right playground flooring can make a difference in how comfortable and durable the space is. There are a number of different types of playground flooring that you could potentially use. Here are some of the different types of playground flooring.
1. Turf
One of the best things to use in this application is turf. Turf is going to be soft and clean for the kids to play on. The downside of using turf is that it can get expensive.
2. Rubber Mulch
Another popular type of playground flooring is rubber mulch. Rubber mulch is available in many home improvement stores. It comes in large bags and you can simply dump it out on the ground. Rubber mulch is very durable and it is extremely soft and resilient.
3. Rubber Tile
Another type of flooring that you could install is rubber tile. Rubber tile is going to give a more defined flooring surface than rubber mulch will. Installing rubber tiles is going to be a little bit more involved and it will cost more money.
4. Sand
Perhaps the easiest type of playground flooring to install is sand. Sand is used in many different playgrounds and you can simply dump it out on the ground.
5. Bark
Bark chips come in a variety of options. They are light and easy to transport, yet relatively inexpensive. Bark mulch will need to be replaced more frequently than rubber materials.
