5 Advantages of Using Shiplap Siding
If you are thinking of installing new siding on your home, you may want to consider shiplap siding. Shiplap siding is durable, easy to work with and offers much more versatility than some other types of commonly used siding materials. Below, are a few of the biggest advantages to using shiplap siding on your home.
Ease of Installation
Shiplap siding is designed using a tongue and groove type joint that makes installation fairly simple when compared to many other types of siding. Even a novice with only rudimentary carpentry skills and a few basic tools can learn to install shiplap siding in almost no time at all. If you are handy with a saw and hammer, you will find that installing shiplap siding is much easier than you may have imagined. Installing some other types of siding on your home may require skills that the average DIY enthusiasts simply does not possess. This in turn, would mean that you have to spend a lot of money on labor and hire a professional to do the job. With shiplap siding, the way the siding pieces fit together is almost instinctual, and most people figure it out within a few minutes.
Versatility in Installation Options
Unlike many other types of siding, shiplap siding can be installed either horizontally or vertically. Therefore, you have much more versatility in the way you can install the siding on your home or structure. Although most installations of shiplap siding follow the more traditional horizontal type of application, there are many times when shiplap siding is installed vertically. For example, many rural structures that use post and beam construction (such as a barn for example) often have shiplap siding installed vertically rather than horizontally.
More Protection Options
In addition to providing a very tight air and moisture seal on its own, shiplap siding provides you with many more protection options as well. With shiplap siding it is easy to use not only felt paper underneath the siding, but you can also use exterior insulation or even a vapor barrier. With many other types of siding, you may be limited to the types of insulation or barrier material you can place beneath the siding in order to protect your home and save energy.
More Natural Appearance
Because most shiplap siding is constructed out of real wood, it offers a much more natural and rustic appearance than vinyl or aluminum siding. In fact, one of the most common reasons that homeowners choose shiplap siding is because of the wide availability of shiplap siding in such beautiful and exotic woods such as cedar or oak.
Easy to Repair
If you've ever had to have aluminum or vinyl siding repaired, you know that it can be a timely and costly undertaking. With shiplap siding, repairs are relatively easy, and you will probably be able to perform many of them yourself. If you have access to a circular saw, a pry bar, a hammer, nails and a few other basic carpentry tools, you'll be able to fix or replace shiplap siding in a matter of a couple of hours or so.
