5 Advantages of Using Toggle Clamps
Toggle clamps are one of the many essential devices a homeowner should stock. They firmly hold down a work piece, keeping it stationary. This allows you to undertake action without being bothered by frequent movements of the work piece. The tool uses a unique pivot and lever system to function. This enables it to hold down a work piece, squeeze, push and pull according to your specifications. Below are five advantages of using toggle clamps.
1. Efficiency
Installation of toggles is easy and fast. The clamps have a high operating reliability. The highly efficient setup of toggles enables you to work quickly and accurately. Due to the high clamping ability the fixtures needed for an application are significantly reduced. This reduces work time significantly.
2. Adaptability
Toggles can adapt to work pieces of varying heights. This is especially true of the Cam-action model which is often used on rough castings and forgings. Strap clamps and T-slot camps have adjustable screws which enables you to apply the desired clamping force. These models have an extremely high exerting force. They also have high adjustability which is helpful when working with materials of varying thicknesses.
3. Versatility
Various types of adjustable toggles are available on the market. Of all commercial clamps on the market, the toggle clamp has the most varieties. Aspects such as handle design, handle placement and pressure ratings distinguish one clamp from another. The clamps are available both in manual and automatic models. This allows for an extensive range of clamp action. Squeeze action clamps have a release lever which makes it easier to open the clamp. The clamps are available in various finishes which enhances visual appeal. It also enhances corrosion resistance. Some common varieties are zinc plated, stainless steel, chrome finish or nickel plated.
4. Improved Safety
The design of toggles assures you of a high safety level when working. The positive locking action keeps both the tool and work piece securely in place. This helps to prevent accidents due to loose grip or slipping. Most toggles allow you to exert a high level of force onto the work piece. The superior holding power is a boost to overall safety while working. Fasteners or strap clamps are used in many devices to activate the power clamps. These often require repeated actions. It increases muscle fatigue and strains. It also subjects the equipment to increased wear and tear. However, toggles are designed to enable a safer way of operating the equipment. This is because of the lever mechanism which requires just a single pull to activate all the power clamps through the same circuit of power.
5. Ergonomics
Toggle clamp handles are designed to minimize strain while working. This allows you to maximize on work efficiency. Most models have contoured handle grips which fit better into the hands. You can manipulate the handles according to your level of comfort. The handle can easily be modified into a bent position which allows you to keep the wrist straight. This helps you avoid fatigue, strain injuries and related problems as you work.
