5 Advantages of Using Tower Speakers in Your Home Theater 5 Advantages of Using Tower Speakers in Your Home Theater
A home theater is a great way to entertain with speakers being the cornerstone of the system and tower speakers can pull it all together. When you want to be entertained or entertain friends and family, then you do not want a speaker setup that will not highlight the movies or music your are presenting. In many speaker packages you will get the basic channel setup. You will wind up with a center speaker, two satellite speakers and a subwoofer or bass speaker. More expensive packages will include two more satellite speakers. Many receivers will allow you to connect multiple speakers to one channel to increase the yield of your sound. If you want to create a perfect speaker setup for your home theater then use tower speakers. The article that follows will show you some of the advantages to using tower speakers.
1. Contemporary Style
Tower speakers, unlike standard sizes in surround sound kits, are high visible. Most speaker components are meant to be tucked away in a corner or hidden between books. They are also small so can easily blend in to their surroundings. Many people who are serious about their home theater systems want their systems to be visible. Tower speakers are sleek and contemporary in style which can go with nearly any theater design you have in your home.
2. Added Sound Depth
There are several styles of tower speakers that you can purchase to add to your home theater system. A popular version of tower speakers will have be those that have more than one speaker in each tower. These multiple speaker towers will have one main speaker and also one or more small speakers. These other speakers add depth to the sound as well as bass. All of these combined create a rich sound that has depth.
3. Versatility
Tower speakers can be added to any surround sound system package you may have purchased. You can connect all of the speakers and hide them in corners and between books while the tower speakers can be seen as your floor units. Just because you add tower speakers to your system does not mean that you have to give up on sound quality. After you are satisfied with your speaker setup the tower speakers can be easily added. All you need to do is to connect the tower speaker wires to the left and right speaker channels.
4. Slim Design
Some speakers are very large which makes them difficult to setup and maintain a clean look to your home theater setup. Years ago tower speakers used to resemble amplifiers you would see at a rock concert but now they have drastically changed. Instead of being wide and squat they are tall and slender. This allows you to place them anywhere in your theater design and they will not take up too much space.
5. Superior Sound
Regardless of your current speaker setup there is always room for improvement. Tower speakers can add this improvement at a nominal cost. Tower speakers will become the cornerstone and the workhouse of your home theater.
