5 Advantages to Using an Electric Mower 5 Advantages to Using an Electric Mower
An electric mower has many advantages. If you have a smaller yard, or a battery operated mower you can find many benefits using the electric variety. Here are just a few of them.
Noise Pollution
An electric mower is virtually silent. Sure, some noise can be expected, but since the engine isn’t a standard gas or oil powered device you won’t have the same decibel of sound. The noise from a traditional lawn mower can actually cause damage to your ears. With an electric mower, you won’t have to worry about such detriments, and your neighbors will appreciate it as well!
No Gas or Oil
With an electric mower you won’t have to mess with getting gas and oil for your motor. If the engine requires a lubricant it will usually be a different kind of oil that is much easier to use than the traditional type used in gas engines. This will eliminate the possibility of accidental spills. In 2007, the Environmental Protection Agency reported that more than 17 million gallons of gas spilled from lawn equipment. Having an electric mower removes this hazard.
Think Green
Many of us have found ourselves thinking more about protecting the environment. We’ve seen gas prices rise over the years to record setting highs. The best lawn mower for the environmentally conscious is an electric powered one. Since they require no gas you won’t be wasting natural resources when you care for your lawn. The EPA estimated that more than 800 million gallons of gasoline is used each year in lawn equipment. Just think of how quickly we could reduce our dependence on foreign oil if every household used an electric powered mower!
Cost Savings
Instead of paying $3-$5 for a gallon of gas, you can pay that $5 to charge your electric mower for an entire year. Not only do you reduce the cost in gas consumption by switching to an electric mower, but the upkeep and maintenance costs are lower as well. You can eliminate the need for tune-ups, oil, oil filters, and other maintenance that will be required for a traditional gas powered motor. Electric mowers may cost a little more upfront, but they make up for it in the long run.
Easier To Use
An electric lawn mower is usually lighter and easier to operate than the gas powered mowers. This cuts back on the time you spend actually mowing the lawn since it will be easier to maneuver. Even a large lawn can be easier to mow if you do it in sections.
An electric mower can be an invaluable asset to anyone who wants to keep their lawn looking great. There are many brands that offer these mowers. You can check lawn mower reviews online to find the best electric mower for your needs.
