5 Benefits of a Hand Rubbed Lacquer Finish
A hand-rubbed lacquer finish may cost slightly more than other types of finishes, however, there are a number of reasons why this is better. Hand-rubbed lacquer finishes offer a number of advantages over similar types of lacquer finishes. When justifying the extra cost you should take a look at the benefits to decide whether or not it's worthwhile.
1. Beauty
Hand rubbed lacquer finishes are unique and interesting, this adds to the beauty of the finished piece of equipment. Hand rubbed lacquer finishes are more expensive because they take much longer to perfect, however the effect is certainly well worth it. These hand finishes are very special and add an extra something to the metalwork.
Lacquer hand-rubbed finishes are available in a wide range of different colors and patterns which can blend into any style of room. It's well suited to old traditional homes, but it can also be used in much more modern rooms. Wherever the lacquer finish is used it will work really well.
2. Durability
Hand rubbed lacquer is also very hard wearing and durable, nothing should be able to damage these finishes because they are water resistant. Lacquer is a gloss finish which makes it virtually impossible for any liquid to work its way inside the metal and create a stain.
Virtually the only thing which can damage lacquered finishes are chips and scratches. Small scratches can simply be polished out, however chips will need much more work to repair.
3. Clean
One of the best features about any lacquer finish is that they are very easy to clean. Because they are hard gloss finishes, they can easily be wiped off with a damp cloth. A damp cloth should make it possible to remove any stain or damage very easily.
Polishing should be enough to remove scratches from the surface of the lacquer and also restore its shine. There are a number of specialist cleaning products available which are well suited to cleaning Lacquer finishes. Polishing machines can be used to remove even the worst scratches, these can often be fixed into most electric drills and will make removing scratches easy.
4. Repairs
A useful feature of hand-rubbed lacquer finishes is that it's possible to repair them if they become chipped. Professionals can repair these, although it's possible to repair some chips yourself using a repair kit purchased from a DIY store. Repairs to a lacquer finish can be difficult, so it is advised that you talk to a professional with experience before attempting a repair yourself.
5. Waterproof
Hand-Rubbed lacquer finishes are also completely waterproof, which means they are suitable for a wide range of different applications. They can also be applied to metal, which will normally rust to prevent it from being exposed to moisture which could cause corrosion.
Hand rubbed lacquer finishes are well worth the additional cost you will need to pay for them. There are several reasons for this which is why you should give this some careful thought before deciding what to do.
