5 Benefits of Building a Retaining Wall
When it comes to building a retaining wall, there are many reasons that property owners might want one of these kinds of installations. A simple retaining wall involves some kind of strong materials, i.e. stone, brick, etc., that get placed within a greater topographical context. Often, a nearby soil grade will be adjusted to fit in with the new retaining wall, where the end result may be more level. Here are some of the top reasons that property owners choose to install a retaining wall in an outdoor space.
1. Retaining walls for aesthetics – In many cases, a retaining wall just makes an outdoor space look better. Retaining walls can help those who have to deal with tricky grades, where it seems like a slanted piece of ground just isn’t much good for anything. With a simple retaining wall and leveling strategy, that same space can be used for a patio, garden or anything else that the property owner wants on site.
2. Helping with property resale – Another reason that some property owners want to install retaining walls is to help promote the overall value of the property to a buyer. Although agents and others might not consider a retaining wall to make a specific difference in regard to property value, the fact is that adding retaining walls and leveling uneven yard spaces can make a property more appealing when it’s time for resale.
3. Preventing erosion – A lot of environmentalists might be able to explain just how retaining walls are placed for ecological benefits. In areas where soil has a vulnerability to erosion, a retaining wall can help a great deal in keeping earth where it needs to be over time.
4. Additional landscaping – As mentioned above, a retaining wall can make a previously challenging area much more useful. Terracing with retaining walls is one strategy for getting rid of a bland, uneven landscape, where the owner can replace it with any kind of appealing shrubs or plants. It’s amazing the difference that a terraced retaining wall setup can make, also improving the “land use” possibilities for the property as a whole.
5. Storm water runoff – Some property owners want to install retaining walls in order to deal with a large volume of storm water that may threaten the integrity of a building over time. In some cases, local governments actually recommend or even require a retaining wall or other solutions like a retaining basin for excess storm water, as runoff handling becomes a much more significant issue in many communities.
All of the above are reasons why you might want to install a retaining wall on a property. Choosing the best brick, stone or other materials can add up to a beautiful result, that will not only protect a property, but make it a more inviting place. It’s worth looking at all of the options and cost for a retaining wall in any area where uneven ground, runoff or other problems can be fixed by changing the grade of the local area.
