5 Common Metal Working Lathe Problems to Prevent
Metal working lathe is an extremely useful piece of equipment that you can use in your workshop. For those who do extensive metal work, owning a metal working lathe is very important. However, having said that, it is also important to note that this piece of equipment is as dangerous as it is useful. It may increase the range of jobs that you can do, but it can also cause accidents. There are many different lathe problems that can occur while you are using this tool. Fortunately, most of these problems can be avoided.
1. Metal is not Cutting Properly
This usually happens when the cutting tool has not been set properly. Before you begin working, always check the cutting tool installed on the metal working lathe and make sure that it is placed right in the center. The proper positioning of the cutting tool is important to ensure that the cuts are made accurately. As you cut the metal, the tip of the cutting tool may become heated due to friction. Give the equipment frequent breaks so that the tools cool off and the chuck does not rotate at a speed that cannot be controlled.
2. Metal Working Lathe Is Not Working Properly
The tailstock of the metal working lathe may not be fixed properly. Although the tailstock does not have any specific purpose, it has to be locked down properly before the chuck can be fed into the metal. If the tailstock remains loose, the metal may not be cut properly. To tighten the tailstock, inspect the screws closely, and if they are loose, tighten them properly.
3. Carriage Is Not Moving
It is important to know how to move the carriage of the equipment. The carriage moves along its tracks. Moving the carriage is something that needs to be mastered in order for the machine to work efficiently. Along with the carriage, the power feed handles also have to be worked properly.
4. Threads Are Not Being Cut Properly
In a metal working lathe, the cutting of the threads is controlled by a dial. It is always easier to control the dial when you are working at a lower rpm. To be able to control the dial efficiently, test the dial at different speeds by using different kind of feeds. With each feed and speed, examine the ease of handling that you experience. This way, you can get a feel of working and controlling the dials before you actually begin using the machine on the metal.
5. Accidents
Metal working safety cannot be stressed enough. Safety is crucial whenever you are working any kind of machinery. Safety Goggles are a must if you want to protect your eyes. If you are wearing long sleeves while working, make sure that they are either buttoned or folded so that they dot no get caught in the equipment. The carriage needs to be cleaned regularly so that metal dust does not settle on it. Keep a brush at a handy distance so that you can brush off stray metal particles. These metal particles have a way of settling on your skin while working and may cause bruises and scratches.
