5 Evaporative Coolers You Can Buy Right Now
- 50-1,500
With the weather warming up, you may find yourself breaking a sweat inside. Whether you're in a dorm room or your forever home, no one wants to overheat in their living room. If your current cooling system isn't cutting it, an evaporative cooler may be just what you need.
What is an Evaporative Cooler?
What is an evaporative cooler? Sometimes called a swamp cooler, an evaporative cooler uses water evaporation to cool the room. Because water absorbs heat quickly, an evaporative cooler uses that scientific principle to suck up the heat in your room. Evaporative coolers are recommended for dry climates with low natural humidity. You may have heard these coolers called desert coolers because they work very best in hot, dry climates.
Evaporative coolers can quickly cool your space and will use less energy than traditional cooling methods. You don't need an electrition to install one of these air conditioning units for you. You can purchase an evaporative cooler online and simply plug it in in the room you want to cool down.
These handy cooling devices can really cool a room, but as a word of caution, can also warp un-framed pictures and posters near them. If you'll be using your cooler around pictures and posters, we recommend moving them because the humidity created by the swamp cooler can warp them. We also recommend moving the cooler away from books and other paper items.
Where to Buy One
If you're in the market for an evaporative cooler, you can find them at hardware stores, big-box stores, and online. There are tons of coolers on the market so make sure to read reviews and make sure that you pick the cooler that works best for your space.
Coolers are available in a wide range of sizes and aesthetics and price can vary quite a bit from cooler to cooler depending on power and functionality.
Our Favorite Amazon Evaporative Coolers
1. Hessaire MC18M Portable Evaporative Cooler
This portable cooler is great because you can move it from room to room and it cools up to five hundred square feet. This cooler also has thirteen hundred CFM (cubic feet per minute) which basically means that this cooler gets the temperature down fast.
This model boasts good reviews and has a handful of color options that make it easier to match your aesthetic.
