5 Fiberglass Shower Stall Maintenance Tips
While a fiberglass shower stall is a basic for all bathrooms, with time the shine seems fades because of continuous use. Most of us wish to make these stalls last a long time and keep their brand new look intact. That can be done by following a few simple maintenance steps. These steps are neither heavy on your pockets nor are they difficult to implement.
Cleaning the Stall
With regular use, the stall surface becomes foggy due to exposure to water and soaps that form a grimy scum over the fiber. Use a shampoo or liquid soap to clean the surface. Simply wipe the cleaning agent all over, and then wipe it with a fresh rag or wet sponge. If you do not want to use these products, make do with a vinegar-soaked sponge or baking soda dissolved in water. Apply it and let the stall walls dry naturally. See the results for yourself. Your shower stall becomes as good as new.
Precautions
Never use a hard material on the walls of the stall. Doing so leads to scratches, which mar the elegance of your shower stall. Make sure that the shower door is left open after taking a bath to prevent condensation. Prolonged condensation interferes with the transparency of the stall walls that cannot be restored with any amount of cleaning.
Painting
Another useful tip to maintain your shower stall is to paint it after installation. Doing so saves later cleaning, as the paint forms a protective layer that resists scum. Remove the gloss from the fiberglass by roughening the surface. It can be done with sandpaper. Next remove the dust with a vacuum cleaner.
Now that the fiberglass surface is ready to be painted, fill the spray tube with fiberglass varnish or primer. Spread it evenly without allowing any paint to drip. Proceed from the upper level to that below. Allow it to dry for few hours, then take a fiberglass paint of any brand and apply it in the same manner as the primer. Let it dry. At least 4 coats need to be applied.
Make Your Bathroom Airy
To maintain the shine of your fiber glass shower stall, clean it with plain water everyday. Install an exhaust fan to reduce the accumulation of soap scum or dirt on the shower stalls. An exhaust fan freshens your bathroom and protects the stalls.
Tackling Mildew Fungus
Because of constant exposure to moisture and running water, shower stalls are a haven for mildew. Mildew not only makes the stall area unclean, but it also mars the fresh feel of a bath. If the fungus has already formed, then you simply need to mix equal parts of water and bleach in a spray bottle. Wear gloves, as bleach eats into the skin. Now spray the solution onto the stall portions where the mildew is present. If the layer does not come off, then wipe it with a scrub brush and spray again. Another step that could eradicate such fungal growth is installing an automatic sprayer in the stall that sprays anti-fungal compositions at intervals. It is a cheap and effective way to tackle fungal growth.
