5 Gravel Yard Maintenance Tips
A gravel yard can make a nice addition to your home. Gravel consists of a variety of small rocks that bear different colors and textures. It is a great landscaping tool. Gravel is also low maintenance which makes it an attractive feature for homeowners. It doesn’t take much to keep your gravel yard in good condition. Below are some tips.
1.   Rake Regularly
Dirt, dead leaves and other debris are likely to gather on your gravel. If left unattended, you could easily end up with a pile-up of dirt in your yard. This doesn’t do much for the aesthetic appeal of your home. Use a rake to clear the debris from the gravel and dispose of accordingly. A metal rake works more effectively than a plastic rake. If yours is fine gravel, obtain a rake with thin tines that are set close together. For heavier gravel, use a rake with thicker tines set wide apart. Rake your gravel regularly to even out the surface and improve the appearance.
2.   Weeds
Be alert for weeds on your gravel. The more you allow them to grow, the harder it gets to rid your gravel of them. You can heat water in a kettle and pour it onto the weeds. The roots are destroyed by the hot water which kills the weeds. After a few days you can simply pull out the weeds with ease. However, if you have extensive weed growth you may want to use a weed killer. If you pull out the weeds, it is likely to create holes and more maintenance work for you. It helps if you apply a weed Killer twice a year onto your gravel. This helps to minimize weed growth.
3.   Use a Leaf Blower
Leaves are probably the one thing that you can always expect on your gravel. It is best to get rid of leaves while they’re still dry. If you leave them until it rains, it gets harder to clear them. It also encourages accumulation of water on your gravel. A leaf blower can help you clear the leaves away easily while they’re still dry.
4.   Holes
These may occur on your gravel yard from time to time. They tend to spoil the beauty of the gravel. Fill the holes with sand and then apply some gravel on top. You can then even-out the area with a trowel. Use gravel with sharp edges as this attaches more easily to the sand. Gravel that has rounded edges will not hold well. It helps if you have some spare gravel in your home as it comes in handy during certain maintenance procedures. Do not use soil to fill in holes as it encourages accumulation of water.
5.   Recarpet
Pour some fresh gravel onto your gravel site once a year to help maintain the site. This should be done in the spring or fall. Fill any holes with sand first to provide a good foundation before you pour gravel. Crown the gravel with an inch in the center of the yard. This prevents accumulation of water and encourages proper drainage.
