5 Half Bath Design Ideas
sink
Half-bath design ideas can be very limited since the available workspace in it is very limited. Most of the time you will be working within a confined area, which means that you are very limited in what you can add to improve the room.
Use More Light
To make the confined space appear larger, let more light into the area. Artificial lighting can be used in strategic locations to make your half-bath feel less confining.
Color It Right
To add more depth to the space and to make it appear bigger, use colors that are 1 shade lighter than pale in your half-bath. Such colors include pastel, neutral, and light colors.
Use Space-Conserving Doors
To save more space in the confined area, use doors that slide or fold. You have it almost solved if you installed a door that is like those used in airliners.
Save Money on Plumbing
To save money and space, have your half-bath constructed near the plumbing and main drain lines instead of installing new plumbing.
Establish the Right Dimensions
To have enough headroom in your half-bath, ensure that you have at least 7-feet of ceiling height. If your ceiling is too high, it is better to lower it to the recommended 7-feet to make your half-bath more proportional.
