5 Safety Tips to Keep in Mind while Building Trampolines 5 Safety Tips to Keep in Mind while Building Trampolines
Trampolines are not one of the safest amenities that you can add to your property. Homeowners still like to install trampolines in their yards for endless hours of fun. Some good attention to overall safety and some additional safety protections can help lessen the chances of injury from a backyard trampoline. Some of this involves knowing what kinds of dangers are most imminent with a trampoline. Here are some of the most common types of trampling risks and injuries.
1 - Trajectory-Based Injury
Those who are installing the trampoline have to understand how different kinds of jumping with different trajectories can put the jumper in danger. In some cases, insufficient trampoline space leads to individuals falling off and breaking limbs or otherwise getting hurt. Think about allowing for big bounces and plan accordingly.
2 - More than One Jumper
Another big danger with trampolines is when 2 jumpers collide in midair or near the trampoline surface. This can lead to injuries in mid-bounce. One way to deal with this is to impose strict rules about jumping, limiting the traveling to one person at a time. Jumpers can also wear protective gear if they are worried about this kind of injury.
3 - Springs
Contact with the springs of the trampoline can cause pinching injuries. While jumpers are causing the trampoline surface to violently shift, the springs are expanding and contracting quickly. Homeowners who are installing trampolines can try to limit access to the springs in order to minimize chances of this common trampoline injury.
4 - Ground Clearance
Another common trampoline injury is where people on the ground run into the trampoline bars when there is insufficient ground clearance. The hard steel bars of the trampoline can cause contact injuries. Combine this with the fact that many trampolines have a clearance that is just less than what can accommodate a health toddler, and you can see how many head injuries result from younger family members running head-on into the side of the trampoline. Parents can guard against this kind of injury with sufficient barriers to the trampoline area or extended ground clearance.
5 - Construction
Trampolines that are less solidly constructed can break, causing other kinds of injuries. Make sure that the trampolines that you buy are of good quality, and follow all applicable instructions, making sure all bolts are sufficiently tightened, so that when jumpers put strain on the trampoline, it doesn’t come apart and cause additional danger to whoever is using it.
Most of these trampoline dangers have their own potential solutions. It’s a good idea to think about each one when it’s time to put one of these installations in your backyard or other home space. Even indoors, the trampoline has significant risk, and as an outdoor installation, it’s one of those things that experienced lawyers call a “invitation,” something that can cause liability even if uninvited guests injure themselves through accessing it without permission. Homeowners can write specific riders into their home insurance policy in order to deal with some of this danger, but overall, the trampoline is one of the recreational items that needs the most consideration when it’s sticking out at you from the mail-order catalog.
